Page 6 of 8
Re: Looking for infos
Posted: 18 Apr 2017, 23:14
SECU-2P&H+STEP unit can drive two low impedance injectors with peak-to-hold current ratio = 4 and one stepper motor.
Posted: 19 Apr 2017, 11:59
2-ch P&H injector and stepper motor driver unit. Contains two channels to drive low-impedance (P&H) injectors and stepper motor driver. Designed to drive throttle-body injectors and stepper IAC valve. It is a versatile unit. Can be used either with SECU-3 units or with any other EMS.
Full article.
Posted: 09 Aug 2018, 22:56
by Zastava128
Hello.
I have a question about VE and AFR.
If I fit the ecu on a car with carb can I use a lambda probe to get VE or to check if AFR is stoich?
I rember of Lada Axtec but it's something I can't understand.
In that case how did you get the VE?
Thank you.
Bye.
Posted: 10 Aug 2018, 00:42
Yes, you can.
Posted: 10 Aug 2018, 19:10
by Zastava128
Hello.
Thank you.
There are different lambda probes, I dont' remember how many and when it takes a controller.
What is the right probe?
I don't expect to much in conjunction with a carb, I know rich mixtures kill the probe.
Bye.
Posted: 11 Aug 2018, 01:56
SECU supports wide band and narrow band oxygen sensors. SECU has no embedded controller for wide band oxygen sensors, but accepts analog output for full AFR range and controls mixture in full range (e.g. 8...22).
You can use any type of sensor from any manufacturer, e.g. Bosch 0 258 005 133
Last releases of firmware support heater's control using PWM, this extends lifetime of sensor.
Posted: 23 Aug 2018, 18:15
by Zastava128
Hello.
How to build the right wiring harness?
What sort of wires?
I think that it must not be too long.
What about a car with the rear engine and battery at the front?
What is the right place for the ecu?
I don't think there are many people interesting in fitting a programmable ignition in cars like those.
I already saw that old picture.
Once upon a time I wanted to drive in races like that,just a dream.
If you want you can look for that old movie.
Bye.
Posted: 18 Sep 2018, 12:12
by kommando
If you are using a carb then you can only use a wide band lambda probe, the narrow band will get contaminated from out of range rich mixtures and also will not cover the wider mixture range a carb will give over injection.
Posted: 19 Sep 2018, 19:58
by Zastava128
Hello.
Thank you for the info.
Bye.
Posted: 15 Dec 2019, 03:22
by Zastava128
Hello.
I decided to save some ignition curves for me.
I'm interesting in SOHC Fiat engines. I'm still looking for ignition curves from N/A engines.
- 1.pdf
- (689.83 KiB) Downloaded 148 times
- 2.pdf
- (1.1 MiB) Downloaded 148 times
- 3.pdf
- (1.03 MiB) Downloaded 164 times
- 4.pdf
- (752.8 KiB) Downloaded 158 times
That's a Microplex MED 603B from Uno turbo, you can read the code on it and the engine specifications.
I found other files where the codes are missing,only one is in the file title and the car model in the second file.
I also found the 604C, I don't know if the previous one is a C or a B.
