Hey guys
I‘m new here
I Drive an Volvo tgb with lpg injection
The engine is modified he runs only on lpg with a Venturi lpg Mixer
Also I’ve have installed a turbo
Know my problem
The engine runs normally with a d-Jettronic I have the injectors and a cutted harness
I doesn’t have a ecu
So I want to use a secu bit I doesn’t know wich ecu i Need
The other problem the engine runs in 24v I think I need a converter to 12v right ?
Thx Sven
D-jetronic Turbo 6zylinder and secu ?
- STC
- Your CAR: AZLK 2140
- SECU version: DIY SECU-3
- Has thanked: 2160 times
- Been thanked: 4335 times
- Contact:
Re: D-jetronic Turbo 6zylinder and secu ?
If you use a separate controller for LPG, then it will be enough to select ordinary SECU-3i unit (with hi-z injectors' support). If you want to control LPG injectors directly via SECU-3, then you need to select SECU-3i with embedded peak and hold injector driver (that unit is under testing now and will be available for ordering soon).
Yes, SECU supports only 12V.The other problem the engine runs in 24v I think I need a converter to 12v right ?
