Old tuner new to SECU-3i
Stewart B
Post 06 Jan 2019, 04:45
Greetings from Australia. I have just ordered the terrific SECU -3i and downloaded firmware and manager. Am I missing some information because I cannot edit files offline? I wish to make the fuel and ignition maps plus set up triggers etc, before loading into the ECU.
kommando
Your CAR: Norton Commando
Has thanked: 11 times
Been thanked: 8 times
Post 06 Jan 2019, 13:56
Re: Old tuner new to SECU-3i
Assuming this is on a PC,
Run the secu3 exe file
Click ok on the communication error message (as you have not yet connected a box to the PC)
Then the program will start but with everything greyed out
Using the tabs on the bottom click on the 'Firmware Data' tab
Then look at the bottom right and click on ''Actions on the firmware'
Then click on 'Open flash from file'
Select the firmware file from your firmware folder on the PC
The firmware data will load and can then be modified within the program, save the changes and change the firmware name so the original is preserved as your base.
Note that you need to be careful in the selection of the base firmware file, there is fixed data set by the firmware like if you need fuel injection or not, type of trigger. Once you have the right one then you can play with the editable data. If you do need to change software all is not lost as you can select a new base firmware but then take the data from your previous working firmware by importing from file. Files can get corrupted so save new versions with a changed name so you can revert with only minor changes to recover.
Stewart B
Post 07 Jan 2019, 23:50
Hello and thanks again. I don't seem to see the firmware to open once I click Actions. I get the manager up no problem, click Actions but cannot see 'firmare" to open.
kommando
Post 08 Jan 2019, 11:06
You have to navigate to the folder you have put the firmware files in, once you locate the folder the firmware will be listed. If you can use Windows file manager it will be easy.
Stewart B
Post 12 Jan 2019, 07:50
Great, I downloaded the latest hard work from Alexey and used Win Rar. Worked fine :)
I am preparing the maps and wonder if there is a way to allocate Row Map numbers instead of them being extrapolations of upper and lower map limits? Same with RPM as well would be good. I use software to create VE profiles and fuel and ign maps, you see and prefer to use the predictions Map readings to set the upper load limits. So my Y axis can start from the top row being 102 kpa, 2nd row 101, 3rd 100,4th 99 then 5th 97. Then I drop to 90, 80,70,60,50,40,30,20,10 then use Idle rpm amount , say 700 then 1000 increasing in increments of 500 rpm.
What am I missing in my reading, Sirs?
Been thanked: 2118 times
Post 12 Jan 2019, 17:11
Hello,
In current versions of software you can specify only upper and lower values for MAP axis.
For RPM axis it is possible to specify grid (bins) values. Go to the "Firmware data" tab and find a small button with grid icon (near to calculator icon). Press that button and it will open window where you can edit RPM axis values.
Return to SECU-3 (English)
