MAP sensor intake manifold nipple
valdir
Your CAR: 1976 Brazilian C-10
Post 19 Aug 2018, 00:33
Hello,
Congratulations on this great project!
My engine is a Chevy 261 L6 with siamese intake. Just like on this picture https://forum.ih8mud.com/attachments/gm261-jpg.843263/
Under intake manifold there is a heating system from exhaust. And on side there is a vacuum tube for valve cover vent.
Where should I install the MAP sensor tube nipple?
Another picture of engine side with intake manifold. https://4.bp.blogspot.com/-dDf639WyIKo/ ... 2Bmkgf.jpg
The pictures are not mine, but show same type of engine.
Zastava128
Your CAR: I go on foot
Has thanked: 19 times
Been thanked: 10 times
Post 19 Aug 2018, 01:21
Re: MAP sensor intake manifold nipple
Hello and welcome.
I think somewhere under the throttle.
Wait for other pieces of advice.
Do you need for injection or ignition only?
Hasn't the factory distributor got a canister for vacuum advance?
Bye.
Has thanked: 1028 times
Been thanked: 2190 times
Post 19 Aug 2018, 14:00
Yes. Best place is where all cylinder manifolds tie together.
Zastava128
Post 19 Aug 2018, 16:40
Hello.
If there is enough room, if it isn't too thin you can fit a nipple into the carburator spacer.
3 ports for intake and 4 for the exhaust?
I don't understand very well what happens on siamese ports.
Is your engine stock or modded?
Bye.
valdir
Post 19 Aug 2018, 18:44
Thank you all for the prompt answers!
My engine is stock from 1976.
First I'll try with ignition. Injection only in future.
I'm going to use 3 double coils for wasted spark and a 60-2 trigger wheel.
This is a picture of my carburator model. With vacuum advance nipple right under throtlle. https://bit.ly/2w8orRO
Do you think I will get right pressure reading from this nipple?
About siamese ports. You are right, 3 intake for 6 cylinders and 4 exhaust.
This is a picture without the manifolds. The circle ports are for intake on cylinder 1, 2 and 3, 4 and 5, 6.
The square ports are for exhaust on cylinder 1 and 2, 3 and 4, 5 and 6. The 1 and 6 are alone.
http://remanufactured-engines.com/235%2 ... 0block.jpg
Zastava128
Post 19 Aug 2018, 21:42
Hello.
I found that picture. It already uses vacuum advance.
The nipple under the throttle is right for intake manifold vacuum.
Don't worry for the signal, six big cylinders, a common manifold and a throttle only give a strong signal,high vacuum.
Bye.
Return to SECU-3 (English)
