Help to choose right setup
Arnis
Your CAR: Volvo 164 b30a
Post 02 Feb 2019, 15:42
Re: Help to choose right setup
May be this file can be modded to calculate base ignition table for secu ?
this file is not password protected
Ignition_timing_konfigurator_opstartsmap_v106.xlsx
(56.6 KiB) Downloaded 15 times
Has thanked: 1028 times
Been thanked: 2194 times
Post 02 Feb 2019, 15:56
I guess, it can only generate a near avarage curve (in best case) for your engine. All engines are different and run under different conditions. You should tune it by yourself.
Arnis
Post 02 Feb 2019, 16:15
That I understand, but how to tune it? by ass feeling?
Post 02 Feb 2019, 16:40
Arnis wrote:That I understand, but how to tune it? by ass feeling?
Yes :) You can write logs and insert markers (hot keys or item in the main menu of SECU-3 Manager). Then, you can manually adjust tables by analyzing markers in logs.
Zastava128
Your CAR: I go on foot
Has thanked: 19 times
Been thanked: 10 times
Post 02 Feb 2019, 21:45
Hello.
STC wrote: You can write logs and insert markers (hot keys or item in the main menu of SECU-3 Manager). Then, you can manually adjust tables by analyzing markers in logs.
Is there an example somewhere? I have no idea of its meaning.
Arnis wrote:May be this file can be modded to calculate base ignition table for secu ?
I can't use it but it can't guess all values for your engine. You can use all values you know about the original ignition.
You can look for them on manuals, you can check the ignition curve by a timing light, if you haven't got a timing light you can discover the timing at the idle by turning the engine by hand and looking at the engine marks while breaker point is opening.
By printing a wheel degree and fitting it on the mechanical advance of the distributor you can discover the centrifugal max advance,you can do the same for the canister adavance.
Here you can find another xls file using values you give.
viewtopic.php?f=14&t=65
If I could use it I would have given you the 16x16 chart.
Bye.
Zastava128
Post 02 Feb 2019, 23:05
Hello.
I took two pictures from a guide. I don't know what the guide explains.
They suggested me an idea to discover the ignition curve.
It takes something that make the distributor to turn and that let you adjust the distributor speed, a lathe machine,ain't I right?
I know a timinlg light is littler and cheaper than a lathe machine. If you alreday have got it you can try and then rember that revolutions and degrees are doubled on the engine.
Bye.
Arnis
Post 11 Feb 2019, 16:17
Im reorganizing all.
and redo relay wiring, but before please check....
is this correct?
I separated add_I2 to Map_s cose I have internal Map sensor
PS i removed r22 for IGN
And If I use
ADD_IO2 as GD_DIR
IE as GD_STP
do I have to add or remove any resistors?
Arnis
Post 11 Feb 2019, 21:07
Post 12 Feb 2019, 00:04
is this correct?
Looks like it is correct.
And If I use
ADD_IO2 as GD_DIR
IE as GD_STP
IE is high-side output. You need pull up 1...2k resistor between IE and ground.
Arnis
Post 12 Feb 2019, 22:59
excellent! tested and ignition works now.
next problem
I checked 0 angle and strobe shows -3degr. but changing octane correction not reacts. I used real time map.
CE output is connected to relay as GND to invert output as + . my dash needs 12v to activate lamp. but lamp dose not go on .CE is forced to display .
do I miss something?
Thanx
Return to SECU-3 (English)
