Help to choose right setup
Arnis
Your CAR: Volvo 164 b30a
Post 17 Jan 2019, 08:31
Re: Help to choose right setup
Haw to change pulse width?
Has thanked: 1028 times
Been thanked: 2194 times
Post 17 Jan 2019, 14:57
Zastava128
Your CAR: I go on foot
Has thanked: 19 times
Been thanked: 10 times
Post 18 Jan 2019, 19:32
Hello.
Will you use the stepper motor for closed loop on LPG?
I can't understand the last things you talked about.
Now can you turn the engine off?
Thank you.
Bye.
Arnis
Post 18 Jan 2019, 22:12
Im thinking abaut lpg stepper. But later. Now i have to let the car on streets. And then start tuning .and get more info abaut it.
Abaut wireing.
Secu is connected to power with relay.
Coil to ground and plus to ignition (acc).
Key on- secu on , key off- secu off.
But when engine runs turning key acc off engine still runs.
I thoth to see what is going on with tester lamp connecreed to acc.
3w lamp connected to acc wire
Key on - light on, secu on. OK.
Key off- light off, secu off. Ok
Cranc engine .lihht on ,engine runs. Acc off. Engine off. OK.
But without lamp engine keeps running
Post 18 Jan 2019, 22:59
Arnis, the reason of such behavior may be in following. Make sure that after ignition become off voltage at the IGN input falls to zero. Also, it may need to set inversion check for that input.
Tell me which input you are using for IGN?
Arnis
Post 22 Jan 2019, 00:44
OK,
I guess I need my free input PS rename to IGN and connect to car ACC cable and all will work. right?
did not find any info about input ign remapping for acc
Post 22 Jan 2019, 16:44
Post 22 Jan 2019, 16:45
If you want to use (reassign) PS input as IGN, then it is better to solder out resistor R22 (2.7k).
Arnis
Post 22 Jan 2019, 20:35
thanx,
I thought its enough to connect power to secu pin 12v with relay and activate relay coil by acc.
here is my electric wiring
Arnis
Post 01 Feb 2019, 23:52
ok changing pulse with did not change. sense I have my dash android arduino based I had to change sketch. now tachometer works perfect.
can not find or understand how to generate ignition map for my engine.
could YOu point me where I can find info no that.
phpBB [video]
Return to SECU-3 (English)
