Help to choose right setup
Arnis
Your CAR: Volvo 164 b30a
Post 09 Aug 2018, 14:21
Re: Help to choose right setup
Thanx for information!
I still have not got all together. hope in September I will have more time to dig in.
I have collected all parts for secu but now I'm fighting with my digital dashboard
Zastava128
Your CAR: I go on foot
Has thanked: 19 times
Been thanked: 10 times
Post 09 Aug 2018, 21:47
Hello.
Very nice colour. Your project is amazing.
I'll wait to see the job on the car.
I have no skills in electronics and softwares. Your dashboard is too complicated for me.
I can't use the Secu-3 at the least.
I found some ignition curves,they aren't from Volvo manuals.
Thoose infos aren't enough to draw an ignition curve. There are values for E85 and LPG. The same curve for two different fuels.
I rember about T.A.P.(timing advance processor) that could be added on old LPG/CNG system.
They add more advance on the factory ignition curve. There are switches that can add 3°,6° and so on.
The first generation of TAP was made so.
Then they a curve to modify the factory one,the same correction for all cars and engines.
I couldn't find any exemple of thoose correction curves.
Then they made programmable ecu or TAP.
I can't give an help unfortunately.
What about the trigger source for Secu-3?
Will you use a trigger wheel on the crankshaft pulley?
Thanks.
Bye.
Arnis
Post 10 Aug 2018, 11:07
Have to make spacer
Zastava128
Post 10 Aug 2018, 19:05
Hello.
That's very kind of you.
What about the TPS? Is it an automotive one? Is it a contactless one by Hall sensor technology?
Why did you choice the TPS? Because an aftermarket camshaft, because constant vacuum carb or other reasons?
Thanks.
Bye.
Arnis
Post 11 Aug 2018, 00:53
End switch for carb.
Was cheap on aliexpress.
Still missing stepper motor for automatic chocke. Can not finde one. Have to finde a way to get from Russia.
But first thing Ill try to start the engine after rebuild and see that all is working with stock system and then install secu.
Well Im gona fix crancshaft position reading cose after putting in radiator there is not much space to work.
What car You have?
And digital dash nowdays is "kindershpiele"
It runs on arduino
Zastava128
Post 12 Aug 2018, 00:19
Hello.
I haven't got a car at the moment. I had some cars but without license plates, owing to pollution laws and so on they were like special waste. It isn't easy to own cars ad collector, it takes a garage at the least. I haven't got one.
I must wait...
I can't use arduino,it isn't easy for me. I know, for a student at the secondary school or less is a joke.
Probably that stepper motor was used on Lada only. I didn't know it, I leraned about it here.
I couldn't find a TPS like yours but it made me remeber about other sensors with four or more pins.
Bye.
Arnis
Post 25 Nov 2018, 17:49
hi,
finally I got engine running with stock system after total rebuild. And now Iam ready for secu installation.
Please check my setup blueprint if I have made it correct
and If I have 60-2 trigger wheel and 6 cylinders haw many teeth You recommend to leave ? 12?
and I have hi voltage tachometer. What setup You recommend for me? Like I made in blueprint
Thanx
Been thanked: 2118 times
Post 25 Nov 2018, 22:41
1. Please shunt all relay coils with diodes (1N4007 or other general purpose diode)
2. REF_Sx are inputs, not outpus and can not be used for SM_DIR and SM_STEP. Use remaining free outputs, e.g. ADD_IOx or BL, DE on the board.
3. Possibly you will need a 5k resistor between tachometer input and ground
4. If you mean number of teeth BTDC, then it should be 12...20. So, 1-st tooth will be at least 70 degrees BTDC (recommended)
Arnis
Post 26 Nov 2018, 00:41
1.ok
2.ok got it
3.got it
4. yes. recommended 9 teeth. to get 70deg 13 teeth should be ok?
This is my trigger wheel. well not cut out teeth yet
Arnis
Post 26 Nov 2018, 00:46
Witch way is better to connect tachometer?
with diodes or Hall_out?
Return to SECU-3 (English)
