Help to choose right setup
- Your CAR: Volvo 164 b30a
- SECU version: DIY SECU-3T
- Been thanked: 2 times
- Contact:
Re: Help to choose right setup
Maybe in manager can implant when v_gas is activated there is another fuel pump action for gas
- STC
- Your CAR: AZLK 2140
- Has thanked: 2160 times
- Been thanked: 4335 times
- Contact:
See in the SECU-3 Manager a special check box "Turn off fuel pump on gas fuel"
- Contact:
I know that.
I ment to use same fuel pump output for gas to use with diferent time before start.
- Contact:
What Im doing wrong?
I changet IE to CE. But output is only 3v
And it newer worked as CE CE before. Did not get output signal
- STC
- Contact:
In the SECU-3T unit most of outputs have no pull up resistors. Thus, it is not correct to measure viltage at the output without connected load.
- Zastava128
- Your CAR: I go on foot
- Has thanked: 71 times
- Been thanked: 50 times
Hello.
What's the news?
I found the static advance values for other B30 engines. What is the best value for max advance on LPG for your engine?
Bye.
What's the news?
Bye.
- Contact:
hallo,
haw can I use IE output as UNI_OUT1 to have lambda voltage for external AFR gauge?
What do I choose to get out right voltage.
in manager AFR gauge works
secu IE output shows 3.4v
- STC
- Contact:
IE is a high side output, When transistor is on, 12V go to output. 500mA max.
