DIY SECU-3 micro questions
Zastava128
Your CAR: I go on foot
Has thanked: 19 times
Been thanked: 10 times
Post 15 Dec 2018, 22:45
Re: DIY SECU-3 micro questions
Hello.
Thank you very much. That's very kind of you.
Unfortunately I'm a jackass.
I think there is no factory crank pulley for the conversion of old D.O.H.C.
The example I found was made by the same guy who shared those ignition maps on the polish forum.
It seems that the pulley is for two belts.
Maybe it's a little diffrent by the one on the 1608 block.
To use a factory trigger wheel from a later D.O.H.C engine you must swap all pulleys and belts if I'm not wrong.
Bye.
1608cc
Your CAR: VAZ 2106 (1.6 DOHC)
Post 09 Jun 2019, 14:47
Another question to STC ;)
Did You try to use K-Line (ISO9141) protocol instead RS232 ?
I want to add L9637 interface, and I think software must be different then... Hardware won't be a problem.
L9637 is also good idea, because it has additional L-Line converter - it would control bootloader pin.
What do You think about it ?
Has thanked: 1036 times
Been thanked: 2250 times
Post 09 Jun 2019, 23:18
Maybe in the future. I have a lot of other tasks for next months. I suggest you to develop k-line adapter which will convert SECU protocol to k-line protocol. Of course, not all parts of the SECU protocol can be converted into k-line.
1608cc
Post 10 Jun 2019, 18:02
Time is not a problem - if in the future K-Line will be add it is worth to wait :D
Post 12 Jun 2019, 12:11
1608cc wrote:Time is not a problem - if in the future K-Line will be add it worth to wait :D
Which functions you want to be implemented via K-line interface? The problem is that SECU communicates using duplex mode (incomming and outcomming data sent simultaneously). As far as I known, K-line interface doesn't support duplex mode. It is relatively simple to implement just logging (collecting data from SECU).
1608cc
Post 12 Jun 2019, 19:32
STC wrote:Which functions you want to be implemented via K-line interface? The problem is that SECU communicates using duplex mode (incomming and outcomming data sent simultaneously). As far as I known, K-line interface doesn't support duplex mode. It is relatively simple to implement just logging (collecting data from SECU).
Yes You right, K-Line is Bi-Directional Half-Duplex bus - so in this case it won't work, if I connect interface straight to UART :|
I want all functions will be implemented - not only logging. So now only way is waiting for full support of K-Line interface in the future ;)
Post 12 Jun 2019, 21:06
Yes. And use interface IC like this https://www.nxp.com/docs/en/data-sheet/MC33660.pdf
1608cc
Post 12 Jun 2019, 21:28
STC wrote:Yes. And use interface IC like this https://www.nxp.com/docs/en/data-sheet/MC33660.pdf
I will use L9637 - it's better than MC33660, because it has additional L-Line comparator I will use as "bootmode switch"
Post 12 Jun 2019, 21:40
Thank you for information.
Return to SECU-3 (English)
