Renault 19 C2J 790 карб
Zastava128
Your CAR: I go on foot
Has thanked: 19 times
Been thanked: 10 times
Post 22 Oct 2018, 19:10
Re: Renault 19 C2J 790 карб
Hello.
That's a Renault distributor by Ducellier.
There are three numbers for the code of centrifugal advance and two for the canister advance.
I found other ignition advance curves,probably are from R 4 and F4.
Many curves aren't new,it's a long liust to check,C 52 is new, I'mnot sure about centrifugal curves but I think thre is something new.
Bye.
Zastava128
Post 23 Oct 2018, 02:00
Hello.
That's a distributor from a Dacia.
I can't see the last number,maybe the code is 3239?
They are from Cleon Fonte engines,they are Renault derived.
The codes on distributors are different from Ducellier ones but ignition curves can be equal.
I found some datas.
There's the code C34 for the canister curve.
Manuals aren't very accurated, I saw the same degree values of distributors on injected manuals so I ignored that manual.
Zastava128
Post 23 Oct 2018, 02:04
It's strange to see a 1289cc engined Nova.
Bye.
Hello.
At the moment there are three different distributors only.
The problem is that on manuals datas about curves are little different.
The next is from a 1300 manual.
Bye.
Zastava128
Post 24 Oct 2018, 04:18
Hello.
Another manual.
Bye.
Zastava128
Post 25 Oct 2018, 00:25
Hello.
From other Dacia manuals.
Nothing new.
If there are three distributors datas on a manual they add two graphic the same for canisters.
Electroprecizia doen't make distribuotrs anymore, you can buy a new one of course, I don't know who makes them.
On the Asam catalogue there is the coil only for old ignitions,nothing else.
You can find a new distributor in a shop on line but it's always the same for all engines.
Once upon a time i tried to ask Electroprecizia for more details but tehy din't answer,it was manu years ago.
The distrbutors were different ,I never understood all details.
It isn't a problem, by a programmable ignition you can get a better ignition map, it takes some tests so I don't care too much if infos on manuals aren't always the same,if they are approximmated.
Bye.
Zastava128
Post 04 Nov 2018, 20:46
Hello.
Maybe my qustions about 19 Europa could seem funny or stupid.
I didn't know about that version, now I found its brochure.
Are there differences between the 19 Europa sold in Turkey and abroad?
Can somebody add any information useful for engine swap,parts or tuning,please?
The turkish 1.6 is 1565cc, the other one is 1598cc, the second engine has got more hp.
There are no infos about its bore and stroke but it could be a stoker version of C2J like 1.6s from old Dacias.
Bye.
Zastava128
Post 05 Nov 2018, 22:09
Hello.
That's a Ducellier distributor from a persian R5.
I don't know nothing about the car where it's from.
I have a confusion about Saipa,Sepand and all other brands and names.
I found that picture.
Maybe it's by Saipa but I can't understand why there is the Renault brand.
Maybe they used to import parts to build tem, I saw other part made in France or abroad, on an old used gerabox I could read "Industria Argentina".
I try to find the story of the persian car but somewhere there are written different things.
I found the brochure of Sepand PK, a R5 body on a kia Pride platform.
Generally You found around infos about an injected 1300 engine, somewhere is talked about a 1100 engine from Hyundai but I think it's a wrong info.
I was fortunate to have found that whole bochure. Unfortunately I didn't find the same for Sepand and Sepand II.
They were made before the PKs.
That's the same as the Saipa 5.
The Sepand II is just a little bit different.
Pars Khodro SEPAND II.jpg (7.81 KiB) Viewed 832 times
The quality of Sepand isn't the same as Saipa.
I fount those too but I'mnot sure they are genuine because the car pictures.
There are Sepand II engine code and its capacity.
Are there 1108 engined only?
What were engines used by Saipa?
The power of Sepand II engines is very low.
Even if I don't know all persian engines specs I'm nearly sure that it's possible to find ignition curves in the long list i did.
I often saw people adding a temperature gauge on that car.
I like very much the one added by the factory on Sepands.
Bye.
Zastava128
Post 09 Feb 2019, 23:28
Hello.
Other ignition curves from a Renault Clio distributor.
The timing advance at the idle is 10°,the engine code is C1E.
That's from R 11 manual.
The same as the Super 5 workshop manual,no new ignition curves.
Other ignition curves from Renault 4 workshop manual,nothing new.
The last one should be new,I couldn't find the R.280 on previous pages.
Bye.
Previous
Return to Renault
