SECU3 Micro на ВАЗ-2107, Карб.+Метан.
Zastava128
Your CAR: I go on foot
Has thanked: 19 times
Been thanked: 10 times
Post 17 Dec 2018, 22:06
Re: SECU3 Micro на ВАЗ-2107, Карб.+Метан.
Hello.
Those are T.A. TAPs.
They are programmable.
There is the curve for a Ford 1.3 Rocam engine.
I don't think we can use it. They used a dinamometer for mapping. Who can use a dinamometer or a rolling road?
That's why I thought there must be maps stored when I saw a CD with car brands.
Now I don't think so.
Do you use standard spark plugs? They sell spark plugs for gas.
There are two sorts of conversion kit by TA Argentina, closed loop and open loop.
I couldn't understand the difference,then I saw some conversion kits on a BRC manual.
The open loop one is for cars with carburators.
It should be so, it's from BRC.
The closed loop one.
That kit is for injeceted petrol cars, CNG isn't injected, there's still the mixer.
Those are from BRC.
Zastava128
Post 17 Dec 2018, 22:34
I'd like to show you all a video.
https://www.youtube.com/watch?v=IGQVwxQlK2c
I don't know the truth about old TAPs, everybody tells somethind bad about them and then they show their products.
Probably the curves weren't always the same, they used to change according the cylinders numbers and car ignition systems.
"Korrekcia".
On CNG they uses the 12° curve.
I don't know who check them and how,I don't know anything about the car ignition system and the TAPs.
I found two ignition curves.
1100 rpm/9°,1500rpm/12°,2000rpm/12°,2500rpm/12°,3000rpm/9°,4000rpm/9°,5000rpm/6°,5700rpm/3°.
It looks a lot of adavnce at high rpm.
Another one.
800rpm/6°,1200rpm/12°,3500rpm/12°,then it decreases,5000rpm/0°.
Don't use them if you haven't got any skills in mapping.
Bye.
Arman
Your CAR: ВАЗ 2107 1.5L
Has thanked: 214 times
Been thanked: 57 times
Post 17 Dec 2018, 23:41
Zastava128 wrote:
I am very sorry, but why do you write all this to me? I saw it all and read it.
If you want to post useful information, post it on the forum, and not in my topic.
In addition, there is a Russian section here, for English there is a corresponding section and it is difficult for me to communicate with you in English.
Please do not litter my topic.
I apologize again...
viewtopic.php?f=19&t=1057
Михаил_60
Your CAR: ВАЗ 21053
Post 08 Jan 2019, 17:08
Привет форумчане.
Для переключения карт бензин - газ в SECU 3 Micro можно использовать переключением вывода GAS_V.
При подаче +12 в работает карта на газу, а при отсутствии +12в на бензине.
По этому поводу вопрос.
Если вывод GAS_V на бензине , то что лучше :
1. или он должен висеть в воздухе;
2. или его лучше подключить к GND , т.е. на землю.
Been thanked: 2118 times
Post 08 Jan 2019, 17:25
Он внутри блока подтянут к земле резистором.
Arman
Post 08 Jan 2019, 19:25
Михаил_60 wrote:Привет форумчане.
Ничего не надо делать, всё уже предусмотрено в блоке.
Михаил_60
Your CAR: ВАЗ 21053
Post 08 Jan 2019, 20:04
Хорошо, всё понял.
