Data connection turned on and off
Matthias
Your CAR: Testastretta
Post 11 Jul 2016, 21:34
Hello my name is Matthias I'm new here and I now before me an insurmountable task.
I have a Secu3 T USB 644 Mega.
After unpacking and connecting the PC for the first time everything works.
I wanted to install the injection firmware and after that the Manager remained disconnected was not subsequently constructed a "reset EEprom".
I have now the Manager V4.3 Installs. made: "Write Flasch from file". with sonnect the boat pin.
(I have it understood must match that of the manager and the firmware) :shock:
My problem now is the manager always connected 1 second of 2 and second of disconnected.
In setting the com port speeed 9600 at the Manager and com -port boot loader 57600
if setting in Manager 57600 and 57600 bootloader we established no connection.
In Pc the port speed is set to 9600 .
the connection via Bluetooth is built but also switches on and off.
Have I damaged the EEbrom ??? And there is a file for EEbrom dounloaden.
please to be able to help continue to my project.
please pardon for my bad english,
Has thanked: 1012 times
Been thanked: 1757 times
Post 12 Jul 2016, 02:00
Re: Data connection turned on and off
Hi,
Please use firmware and SECU-3 Manager v4.3.
In the settings of the SECU-3 Manager use 57600, 57600. Do not use check "data in hex".
Try to go to Firmware data tab and if connection is stable, open popup menu and select Reset EEPROM.
Matthias
Post 12 Jul 2016, 18:07
Thanks now it works.
Return to SECU-3 (English)
