Looking for infos
Has thanked: 1014 times
Been thanked: 1766 times
Post 13 Jan 2016, 01:26
Re: Looking for infos
They are the same, except embedded MAP. Same PCB.
Yes it is possible either, to install embedded MAP or to connect external one.
Custom taxes in different countries are different. Ask your customs and laws )
For instance, In Ukraine we pay taxes only if declared value is greater than 150eur.
Please write to order@secu-3.org for more details.
Zastava128
Your CAR: I go on foot
Has thanked: 7 times
Post 16 Jan 2016, 04:39
Hello.
I have a confusion,that's why I didn't pay enough attention to the documentation.
That's for the SECU-3T units on sale at the shop now, it's written but I didn't see it.
I didn't realize that there were different wiring diagram.
It's the same for embedded MAP or external one.
Those are the right exemples for the 3Ts I asked before.
Is it everything right?
Thank you.
Bye.
Post 16 Jan 2016, 22:05
Yes, everything are right. Moreover, these are only examples. So, you can build your custom wiring...
Zastava128
Post 17 Jan 2016, 23:16
Hello.
Thank you very much.
I'm just thinking of a custom wiring.
Pin 3 of J7 is for throttle limit switch,now I know what it is.
In case of injection it's used for TPS,what is its function?
If I want to use a TPS as limit switch with a carburator can I follow the exemple of TPS with injection?
If I want to use a TPS for engine load instead of a MAP must I use pin 7 of J5?
Bye.
Post 18 Jan 2016, 17:15
Hi,
Yes, this input can be used either for simple switch or TPS. In second case, you will need to disconnect pull-up resistor R57 on PCB.
Yes, you can. Software allows using of TPS as limit switch (you can tune special threshold value in software).
Yes, you must connect TPS to J5/7, at least in current versions of firmware. I plan change this behavior in the future, so TPS can be connected to J7/3 and used for engine load.
Zastava128
Post 19 Jan 2016, 02:18
Hello.
I saw other exemples.
There is the distributor like in the first exemple but there is a VR sensor and external MAP.
The next has got two ignition module and two coils for wasted spark mode.
The next has got a two channel ignition module.
There is something strange, I don't see IGN_OUT2 linked.
In the next one cam sensor isn't optional element.
There's written phased,I understood.
I don't understand the note about 5,6,7, 8. Is it reffererd in case of phased ignition for engine till 8 cylinders?
The exemple is for a 4 cylinders,right?
In the exemples the cam sensor is always an Hall sensor but it's possible to use a VR sensor too.
I tried to guess it.
Now it's better about wiring.
Thank you.
Bye.
Post 20 Jan 2016, 03:21
Looks strange because this ignition module has only one input. First channel fired by rising edge, second channel fired by falling edge. This module produced in Russia.
I don't understand the note about 5,6,7, 8. Is it referred in case of phased ignition for engine till 8 cylinders?
Yes, it refers to engines with number of cilinders > 4 (5,6,8).
The example is for a 4 cylinders,right?
Yes, the example is for 4 cylinder engine (how to build full-sequential ignition for 4cyl).
Last picture (Wiring_DUI_DNO_14+12.png) shows how to connect two VR sensors in case of using non-missing teeth wheel.
Zastava128
Post 25 Jan 2016, 22:49
Hello.
That module didn't let me sleep, it's still a mistery for me...
Unfortunately I can't uderstand your explation about it.
I found it in the exemples.
The exemples of Vaz 21099 and Tavria 1102 are the right ones for the installation of two VR sensors, aren't they?
Now I have a question that I can't explain... I hope you understand.
It's about that russian module.
If I used it must I "tell " it to Secu-3? Does it take a special function?
The Vaz 2106 of the exemples uses an ignition module and a distributor.
That module is made in Russia too,maybe the same brand.
He could use the wasted spark ignition without a second phase sensor owing to the 60-2 trigger wheel.
If we swap the module and the coil only will it work fine?
I tought of that question many times... I don't think it works fine if I use the output 1 in the same way as with the distributor.
Sorry for the confusion.
Thank you in advance.
Bye.
Post 27 Jan 2016, 00:02
Don't think about it, because it is full of shit. The only advantage of this module is that it uses single input for control of two channels. You can not achieve good dwell time with it (it will be very hot on idling).
:). Use separate igniters (like BIP373, or IRGB14C40L).
I suggest to use two separate ignition drivers instead of this module. Of course in this case you need two outputs from SECU-3 unit (IGN_OUT1, IGN_OUT2).
Yes. In these examples non-missing tooth wheels(flywheel) are used and it requires additional VR sensor (for origin reference).
You don't need second VR sensor in case of 60-2 (N-2 or N-1), because it has a gap, which acts as origin reference.
In this case (shit module) you should use firmware with "2chig" in its name.
Zastava128
Post 27 Jan 2016, 05:33
Hello.
It's funny to see russian modules in Ukraine and viceversa.
I never tought of using that module. I wished to know about it only. I can't buy it.
I saw modules made in Ukraine and they sell them for export too.
I saw many Oka with home made ignition, coilpack from Lada 16v,unknow circuits, I couldn't understand if they were TCI or CDI ignitions.
The simplest ignition I saw was one modded taken from Samara, standard coil instead of wasted spark one and a cap on the distributor with three cables, ignition module made in UA.
Is it possible to use a 16-1 trigger wheel too? From 16 to 200,right? N-1 or N-2 only?
I asked people if they can be interesting in secu3, at the moment I found nobody.
I must wait owing to money problem,I'll try to learn as more as possible.
I have a question about custom office tax, does somebody know about it in Russia for thing shipped from Ukraine?
I know somebody spending summer holyday there.
Bye.
Return to SECU-3 (English)
Users browsing this forum: Google [Bot], Google Feedfetcher and 1 guest
