Looking for infos
Has thanked: 1013 times
Been thanked: 1763 times
Post 30 Nov 2015, 03:30
Re: Looking for infos
Hello,
Yes, starter blocking is output and can be used for other functions.
There are several other(alternative) functions, for instance: embedded stroboscope, output for tachometer, ignition output(s) etc.
If we use a distributor the outputs become three.
Yes.
A question about distributor as trigger source, can we use hall sensor only?
What do you mean exactly? Please clarify.
I asked because the sensor signal is linked to CKPS1,may we use distributor with vr sensor too?
Yes, you can use distributor with VR sensor.
Zastava128
Your CAR: I go on foot
Has thanked: 7 times
Post 30 Nov 2015, 23:37
Hello.
Thank you very much.
You already clarified it, the question was about distributors with VR sensor.
CKPS1 is + and CKPS2 is - for VR sensor,right?
The difference between VR and Hall sensor is just in wiring, two wires for VR and one wire with a resistor for Hall sensor.
I had a confusion owing to the two different ways of using the ecu, I was thinking of a trigger wheel with 16 theet at the least,that's for flywheel or crank pulley,when you use the distributor as trigger source is different.
If I'm not wrong it's easy to lock mechanical advance on Bosch distributors.
Tha's Yugo 55 idistributor.
There are 60-2 crank pulleys from Yugo EFI or Fiat.
Other crank pulleys from Fiat.
Thre are two theet on that pulley, it can be considered like a distributor If we want use one CPK sensor and the dustributor.
I thought to use the distributor temporary only so it's possible to use an output for strobe too.
I understood that there are + and - outputs.
That's for-
That's for +
I remember the exemple of Travia 1102, thre are two CKP sensors and no missing thoot.
I can do the same thing with a sensor on the flywheel and the second senor on the pulley or into the distributor.
If we have a pulley with two theet must we cut one of them?
Bye.
Post 01 Dec 2015, 22:38
Yes, but it doesn't matter because software has ability to select interrupt edge, so, don't mind it ).
Firmware supports several synchronization methods, you can use pulley with teeth or legacy distributor with Hall sensor.
I think, yes.
Thre are two teeth on that pulley, it can be considered like a distributor If we want use one CPK sensor and the dustributor.
Yes, it can be considered as distributor with 4 teeth. But if you want to use this configuration, please note that firmware requires event to be occured at least 60° BTDC (crankshaft). This is done because of accuracy requirements (especially on cranking).
That's for-
That's for +
Yes. You are correct.
I can do the same thing with a sensor on the flywheel and the second sensor on the pulley or into the distributor.
If we have a pulley with two teeth must we cut one of them?
Yes, you can, but you have to cut one tooth on pulley (another one will still remain).
Zastava128
Post 08 Dec 2015, 05:01
Hello.
I wanted to find a throttle limit switch.
Is it number 3? I didn't know it.
It looks like an adjustable screw.
May a TPS work the same way? I asked myself, I didn't think so.
There are three wires,-,+ and signal.
Then I remember the structural diagram showing the TPS,maybe I'm wrong but I tought the signal wire like a second +.
If i use the + wire and the signal one only will it work like a switch?
One grounded and the other to the ecu,possible?
Thank you.
Bye.
Zastava128
Post 08 Dec 2015, 20:28
Hello.
I didn't know but it seems that TPS can work as a switch.
There is a switch for idle and one for full throttle.
I found a document about TPS test.
It says that the idle contact is tested between terminals 2 and 18 on the TPS.The full throttle contact is measured between terminals 3 and 18.
It's referred to a Porsche 944 document but it must be the same for other TPS'.
On that Bosch TPS pins are 2,18 and 3. Somewhere the codes can be different.
I don't understand what is +,- or signal but it doesn't matter at the moment. The important is that we can use it as throttle limit switch.
Bye.
Been thanked: 133 times
Post 09 Dec 2015, 13:03
Zastava128 wrote:Is it number 3? I didn't know it.
Yes, It is an adjustable screw.
Zastava128
Post 09 Dec 2015, 23:28
Hello.
Thank you.
Bye.
Post 10 Dec 2015, 15:45
Yes, TPS can be used as limit switch (using only "+" and "signal", but I would say "GND" and "signal"). In this case you may need to adjust pull up resistor inside SECU-3 unit. But I propose to use TPS in normal way (it is supported by software and it doesn't matter what you use - carburetor or injection). In this case you should disconnect mentioned pull up resistor.
Zastava128
Post 11 Dec 2015, 20:59
Hello.
Thank you too.
I'd prefer not to touch the interior of secu-3 unit. Better to use TPS in normal way.
Bye.
Zastava128
Post 12 Jan 2016, 23:02
Hello.
Unfortunately it seems that I won't buy any car.
What is the diffrence between the two diffrent secu-3t?
Is it the map sensor only?
Are they just the same? It can be added on the PCB after?
I just ask because I don't know about board tax.
The diffrence in price is little,the sensor isn't exepensive. I'm afraid of custom office cost.
I must ask about it.
Bye.
Return to SECU-3 (English)
