Firmware with fuel injection functionality
Has thanked: 972 times
Been thanked: 1630 times
Post 26 Feb 2015, 16:06
A brief summary of injection
- 4 + 1 sets of injection tables
- Editing of parameters and fuel injection tables in real time (online);
- Simultaneous or single-point injection (in the near future will be implemented semi sequential injection and full sequential injection);
- The calculation method for fuel: Speed Density (uses MAP and AIR TEMP sensor);
- Open-loop IDLE algorithm. Supports PWM and STEPPER idle valve types. (in the near future will be implemented closed-loop idle control with PI regulator);
-O2 sensor AFR fuel correction, closed loop, narrow band (configurable);
- Acceleration enrichment (TPS based);
- Prime pulse (configurable);
- Over-run (configurable);
- RPM fuel cut-off.
Fuel injection tables:
- VE 16*16 (Volumetric efficiency);
- AFR 16-16 (Air/fuel ratio vs RMP and LOAD);
- Cranking PW (Injection pulse width on cranking);
- Warmup enrichment vs coolant temp;
- Injector’s dead time;
- IAC position vs coolant temp;
- IAC position on cranking;
- Afterstart enrichment vs coolant temp;
- Acceleration enrichment vs throttle movement speed;
- Acceleration enrichment vs RPM.
tahiti-range
Your CAR: I go on foot
Post 21 Nov 2015, 22:40
Re: Firmware with fuel injection functionality
Hi !
I have a Secu 3T, and I would like to use it to control the injection of my car. I have remapped the I/O to do it, but I cannot access the Fuel injection, Lambda control, and Acceleration parameters in the manager. The firmware and manager are the one from Feb 10 2015.
How can I access these options ?
Thanks in advance
Has thanked: 119 times
Been thanked: 130 times
Post 22 Nov 2015, 00:52
tahiti-range wrote:Hi !
Thanks in advance
You must use fuel injection firmware to have access to this options. This link is a full binaries 7z archive file with all of versions firmware. There you can find the fuel injection version of firmware. https://github.com/ashabelnikov/secu3ap ... inaries.7z
Post 22 Nov 2015, 03:56
Yes, darxfame is right!
Use firmware file, which name contains "inj".
tahiti-range
Post 23 Nov 2015, 07:04
Thank you guys ! :D
Return to SECU-3 (English)
