Help to choose right setup
Arnis
Your CAR: Volvo 164 b30a
Post 24 Feb 2018, 22:59
Re: Help to choose right setup
thanx. I can read and speak Russian, but can not write. in school missed Russian lessons.
Ill make my diagrm
Been thanked: 1905 times
Post 24 Feb 2018, 23:02
Ill make my diagrm
Ok. We will check it for errors.
Arnis
Post 25 Feb 2018, 01:05
my start
have to check order of cylinders
hope I understood everything correct
Post 25 Feb 2018, 01:15
Yes, it is correct, except supply of ignition coils. You should connect supply of coils before fuse. It should be separate wire from ignition switch.
Arnis
Post 25 Feb 2018, 01:30
STC wrote:You should connect supply of coils before fuse. It should be separate wire from ignition switch.
or should it be directly from battery with relay?
how about software for my setup? what info is needed to program secu
will You have for sale also bip373 and stepper motor and other sensors that YOu suggest. Im from Latvia and we don't have much Russian made parts
and gas_v is to switch between gas and petrol?is it necessary to have knock sensor?
Post 25 Feb 2018, 12:27
Connection with relay directly from battery is best solution.
You need to load secu3t_m644_rev9_dwell firmware file (this firmware is loaded by default). Software for tuning is SECU-3 Manager.
will you have for sale also bip373 and stepper motor and other sensors that YOu suggest. Im from Latvia and we don't have much Russian made parts
List of parts is here http://secu-3.org/store/ All other parts you should buy yourself locally. It is not obligatory to use Russian parts, you can use any parts from any other manufacturers, e.g. GM. SECU can be tuned for different parts and sensors.
GAS_V input can be used for switching between two sets of tables. It is often useful when using two fuels, e.g. petrol and LPG.
In most of cases knock control is not necessary/obligatory on regular atmospheric engines.
Arnis
Post 25 Feb 2018, 16:37
Thanx,
I really like YOur attitude ! This is first time in my live when I see forum with moderator that is so helpful and nice to beginners !
anyway , now I guess Im ready for for purchase.
just one last thing , how about maps? how to tune them for my engine ? I can install hardware but totally dumb in map tuning.
Post 25 Feb 2018, 18:17
You should tune maps yorself or to find related specialist locally. Also, you can find and try maps from different users/engines.
Zastava128
Your CAR: I go on foot
Been thanked: 10 times
Post 07 Aug 2018, 20:55
Hello.
Volvos are too complicated for me,their manuals too.
That's the firing order.
You already know it and there is the right exemple for wasted spark mode.
It's esay to find the workshop manual but I'm still trying to understand how the distributor works and what the ignition curves are.
You're lucky because 30 A has got no negative control,positive only. what does it mean? It's new for me.
That's for U.S.A. only,the vacuum regulator with negative control.
Now something about timing advance.
Bye.
Zastava128
Post 08 Aug 2018, 22:20
Hello.
A B30 engine is one B20 and half.
Now I understood the datas about the ignition distributor, is it a Bosch JFUR6?
Timing advance at the idle is 10°BTDC, max timing adance is 32°BTDC at 3300 rpm on full load.
Advance begins at 950 rpm, 20°BTDC at 1350 rpm,30°BTDC at 2800 rpm and finally 32°BTDC at 3300 rpm.
I hope not to have been wrong.
Then you must add more advance on light load according manifold vacuum.
Advance begins at 100mmHg, at 142,5mmHg it adds 5°of advance,max advance added is at 180mmHg,it adds 10°.
If you use a TPS instead of a MAP sensor you won't consider manifold vacuum.
On LPG it takes a different ignition curve but I can't add any piece of advice.
Maybe you canbe intersting in Volvo manuals.
http://www.240.se/litteratur/tp1054_1.pdf
http://www.240.se/litteratur/tp10868.pdf
Bye.
Return to SECU-3 (English)
