Help to choose right setup
Arnis
Your CAR: Volvo 164 b30a
Post 24 Feb 2018, 20:27
Hallo,
I was looking for "Трёхконтурная система зажигания" but did found nothing and was pointed here.
All day was reading secu information, but got not much smarter.
I have volvo 164 Year 1969 engine b30a with 2 carbs . its strait 6 cylinder. generally its equal vaz classic but 2 cylinders more. and Ill use LPG.
Please help me collect right items for setup.
Thanx
Has thanked: 972 times
Been thanked: 1630 times
Post 24 Feb 2018, 20:34
Re: Help to choose right setup
As far as I understood you plan to build ignition with "wasted spark" configuration. What other devices you plan to control on your engine using SECU-3 unit?
Arnis
Post 24 Feb 2018, 20:48
Yes , I want wasted spark.
I need impulse for tachometer. That s i guess it.
Post 24 Feb 2018, 21:05
Do you know which type your tachometer is? Low voltage or high voltage input? If it is connected to the ignition coil, then it is high-voltage input.
Arnis
Post 24 Feb 2018, 21:09
Its gona be used for arduino with project Virtual dash Venator
Post 24 Feb 2018, 21:15
Arnis wrote:Its gona be used for arduino with project Virtual dash Venator
I guess it is low-voltage input.
For wasted spark ignition control and output for tachometer you need SECU-3T unit and 3 BIP373. You will reassign any free SECU-3 unit's output to HALL_OUT and it will output pulses for your tachometer.
IE and FE outputs are high-side and 12V, others are low-side and 5V.
Arnis
Post 24 Feb 2018, 22:23
ok
so far so good!
So I need secu-3T
3 units BIP373
ДТОЖ
ДПКВ have to figure out how to attach
ДАД or built in
3 units Катушка зажигания
Концевой выключатель карбюратора. What is that? just end switch
spark plugs connect by this diagram and sensors listed above as on all other diagrams
Post 24 Feb 2018, 22:26
It is a throttle position limit switch. You can use either simple limit switch or TPS.
Arnis
Post 24 Feb 2018, 22:33
ok. if I have 2 carbs i use only one tps?
The rest I figured out correct? or I missed something?
can YOu make diagram for my connection case. non of them mach for me from samples?
yea, Ill also add automatic choke
Post 24 Feb 2018, 22:55
Yes, only one.
Correct.
No. There are a lot of wiring diagrams for SECU-3T unit on the our site. Take a look of them http://secu-3.org/wiring-secu-3t/?lang=en If you need, write your own diagram and show us, so we can find possible mistakes.
Also, please read installation manual http://secu-3.org/installation-manual-secu-3t/?lang=en
Our site is fully translated to English.
Return to SECU-3 (English)
