DIY SECU-3 micro questions
1608cc
Your CAR: VAZ 2106 (1.6 DOHC)
Post 19 Feb 2018, 07:42
Hi, all.
I own VAZ 2106, and I want to make SECU -3 micro. So, before I start, I have lots of technical questions :) :
1. Where can I find latest firmware for SECU-3 micro ? (On the download site I see only SECU-3t files)
2. Where can I find FUSES for ATMEGA664 ?
3. Of course, can I programm the uC by the ISP connector on the pcb using USBasp programmer ? (must be sure in 100%)
4. Is there any replacement for the CP2102 (I'm lookig for chip in diferent case).
5. Can I replace the SP0503 diode pack, with single transil diodes ?
Regards,
Christopher
Has thanked: 1014 times
Been thanked: 1766 times
Post 19 Feb 2018, 13:42
Re: DIY SECU-3 micro questions
1. http://secu-3.org/software-19012017/?lang=en or you can test latest test releases viewtopic.php?f=9&t=1191&start=610#p37249 or viewtopic.php?f=64&t=1174
SECU-3T, SECU-3 Lite and SECU-3 Micro are software compatible
2. http://secu-3.org/setting-avr-fuse-bits/?lang=en
LFUSE=0xD7
HFUSE=0xD4
EFUSE=0xFC
3. Sure, You can use USBasp. It supports ATmega644
4. There are several replacements (but not compatible by pins and package): e.g. PL2303, FT232. CP2102 is quite spread and present in most of electronic components stores.
5. SP0503 is TVS diodes pack (not just regular diodes). They are like Zeners, but with small capacity and fast response. Specially designed to suppress fast voltage transients. SP0503 is used for ESD protection. You can replace it with TVS diodes with similar parameters.
1608cc
Post 19 Feb 2018, 14:11
Thanks for your reply :)
Is there PCB project for SECU-3M or I must project my own ?
In the documentation section is only topsilk layer.
Thanks in advance
Post 23 Feb 2018, 02:01
No, there is no PCB design for SECU-3 Micro available to the public for now.
1608cc
Post 04 Mar 2018, 00:52
Thanks for info.
So If i want use SECU-3 MICRO with CKP sensor and wasted spark type ignition, I must use firmware with _dwell suffix ? Do I need to change options in manager / firmware if I will use wasted spark instead one coil and distributor ?
The last question :) :
In my engine (FIAT 1.6 TC) firing order is 4-2-1-3 (ignition on #4 when TDC). Do I need to change anything or it not mean ?
Thanks in advance :)
Post 04 Mar 2018, 12:03
Yes. For instance this one secu-3t_m644_rev9_dwell.a90
You need to set/unset distributor check mark, which is located on the CKPS parameters tab. Set check for distributor spark, unset check for wasted spark configuration.
You should understand how wasted spark ignition work. Thus, you will understand how to connect high voltage wires.
For wasted spark: first coil works on 4,1, second coil works on 2,3.
1608cc
Post 04 Mar 2018, 12:22
Ok, thanks for all :)
Return to SECU-3 (English)
