Using VR sensor in distributor
pmugabi
Your CAR: Toyota MR2 - 3SGE
Post 14 Sep 2017, 10:49
Some Toyotas come with a VR sensor in the distributor. I was wondering if it's possible to wire up the ECU to use that instead of a Hall sensor in the distributor?
Has thanked: 1013 times
Been thanked: 1763 times
Post 14 Sep 2017, 11:04
Re: Using VR sensor in distributor
Can you show a photo of the corresponding trigger wheel?
pmugabi
Post 14 Sep 2017, 12:46
I don't have a picture but the trigger wheel has 24 teeth, I will modify it to 4 teeth as per the manual.
However if you absolutely require a picture I can open it and take one.
Post 15 Sep 2017, 10:08
Ok.
How many sensors are in your distributor? 1 or 2?
Yes, it is possible. VR sensor should be connected to CKPSx inputs. Edge of pulse should appear 60° BTDC (or near to it).
pmugabi
Post 15 Sep 2017, 14:59
There are 2 wheels and 3 VR sensors. I will try as-is and if I get noise issues (happens quite a bit with people who use megasquirt in the same configuration) then I will remove the other 2 sensors.
Thanks, will try it out this weekend.
Post 15 Sep 2017, 21:21
I recommend you to make a photo of trigger wheels inside your distributor and post it here. There is a possibility that SECU firmware may not support your "native" trigger wheels.
Return to SECU-3 (English)
