Failing to synchronize advance angle with stroboscope lamp
CallensAlec
Your CAR: Toyota Yaris 1SZ-FE
Has thanked: 5 times
Post 07 Jun 2017, 12:43
Hello everyone,
We are having trouble synchronizing our advance angle timing with our engine. When the manager shows us an advance angle of 15°, we usually get about a 43° reading on the stroboscope. When using the check-out box on the manager to turn advance angle to 0°in all conditions, we get 10° advance angle. Could this be due to our crankshaft or camshaft signal or is there an option in the manager that we are missing?
Thanks for your help in advance.
Crank- and camshaft signal
Has thanked: 864 times
Been thanked: 1404 times
Post 07 Jun 2017, 17:08
Re: Failing to synchronize advance angle with stroboscope la
Please post here a screen shot of your CKPS parameters tab.
Also, tell us how many tooth before TDC your sensor is set mechanically (should be equal to the "Num of teeth before TDC" parameter).
CallensAlec
Post 13 Jun 2017, 13:56
Thank you for your response. We have an 36-2 set-up as crankshaft trigger wheel with 22 teeth before TDC. We were getting a better reading when changing it to 23 teeth before TDC. As this is for a school assignment, we had to change to a similar engine on a different mount where the reading was ok after all on 22 teeth before TDC. So the problem is gone.
But thanks again for your response!
Return to SECU-3 (English)
