Ignition signal too low
CallensAlec
Your CAR: Toyota Yaris 1SZ-FE
Has thanked: 5 times
Post 24 May 2017, 11:21
We're having issues with our ignition signal.
When nothing is connected to the IGN_OUTx output, we get a clean 5V ignition signal when starting. When connecting the igniter board to the IGN_OUTx output, the voltage drops to 1,93 V, but the signal remains, if measuring from the Coil x outputs on the igniter board going to our DIS coils, we only have about 0,40V left, but still with the signal in it. This is not enough to have a spark for us unfortunately.
Has somebody here already come across this problem or knows how to fix it? We are out of ideas at the moment.
Thanks in advance!
Signal going to coils
Signal measured from IGN_INx on igniter board
Signal with nothing connected to IGN_OUTx
Has thanked: 864 times
Been thanked: 1404 times
Post 24 May 2017, 20:53
Re: Ignition signal too low
It is normal, because BIP373 consumes some current into base-emitter. It is like a Darlington transistor. 1.92V is base to emitter voltage for BIP373.
I don't understand this. Please clarify measuring conditions.
CallensAlec
Post 07 Jun 2017, 10:38
Thank you for this answer. We fixed the problem by using another transistor which allows more current to flow through it at the same voltage.
When we were measuring from the coil output on the igniter board, so the output going to the coils of the KMS DIS coil. That's where we got the 0,4 V signal.
Return to SECU-3 (English)
