How do I use a table to define temp sensor?
jim-bartlett
Your CAR: 1968 Morris Mini
Post 11 Feb 2017, 12:50
I have a SECU-3 Micro and are going to use a Bosch temp sensor.
I will have to define a temperature sensor table, but how do I create it, and where do I put it?
I have ticked the "Use table to define sensor's curve", but where do I go from here?
Jim
Been thanked: 1899 times
Post 12 Feb 2017, 00:25
Re: How do I use a table to define temp sensor?
HI Jim, thank you for your question.
Following picture shows button which opens needed curve. This curve specifies function temperature vs voltage on the sensor.
If you know how resistance of sensor depends on temperature, then you can calculate voltage on the sensor. This can be done using voltage divider formula. Upper resistor is resistor inside the unit, with 5V applied to it. Bottom resistor is sensor's resistance. First, try default values, it maybe already ok.
jim-bartlett
Post 12 Feb 2017, 02:32
Thanks for your great reply. I missed this feature (sorry) but understand what I have to do now.:)
Return to SECU-3 (English)
