SECU-3 Micro Configure GAS_V as O/P
jim-bartlett
Your CAR: 1968 Morris Mini
Post 11 Feb 2017, 10:33
Hi. I'm in the process (finally) in configuring the SECU-3 Micro to drive my 1968 Morris 1310cc 4cyl Mini ignition. I will be using:
1. A Hall effect TPS -> CARB
2. A GM temp sensor -> TEMP
3. 1 wasted spark coil (VAG logic level, so will be driven directly from SECU-3 Micro -> IGN_OUT1 & IGN_OUT2
4. 1 VR CKP sensor using a 36-1 sensor wheel -> CKPS1 & CKPS2
5. GM 1Bar MAP Sensor -> MAP_S
My question is, can the GAS_V be configured as an O/P? I want to use it as an O/P to drive a solid state relay for my electric radiator fan.
Jim
Has thanked: 876 times
Been thanked: 1475 times
Post 11 Feb 2017, 14:19
Re: SECU-3 Micro Configure GAS_V as O/P
Hi,
GAS_V is input, not output. Because, two existing outputs are already busy, the only way to control a relay is to add several components (transistor, two resistors and diode) and connect them to the one of MCU ports.
Post 11 Feb 2017, 23:19
For using electromechanical relay or solid-state relay:
Return to SECU-3 (English)
