Discussing the 4-channel P&H injector driver unit
http://secu-3.org/4-channel-pnh-injecto ... r/?lang=en
4-ch P&H injector driver unit
- SECU version: DIY SECU-3
Re: 4-ch P&H injector driver unit
Example of using P&H unit with standard ECU (J5.1)
Bare PCB for this unit is here.
- Your CAR: Volvo 122+rotrexB234
- SECU version: I don't have SECU yet
4 channel Peak&Hold driver
Hello,
I'm using a KDFI V1.3 ECU in my car with duel fuel application. (Table switching).
For gasoline i use high Z injectors and for LPG i use low Z injectors.
For the Low Z injectors i would like to use your 4-channel peka and hold driver.
The injectors are 3ohm, can i use this driver?
thank you in advance,
Sven
Sven
Re: 4 channel Peak&Hold driver
If you mean this driver https://secu-3.org/en/product/4-ch-driv ... injectors/, then you can use it only for injectors with 4/1 peak to hold current ratio, so 4A peak and 1A hold. Check documentation on your injectors.The injectors are 3ohm, can i use this driver?
Hi,
I have ordered the unit.
Waiting for delivery, in the mean while i have an question about connection.
Must each output be connected to each injector? Mine fuel ECU has two channels and each channel is connected to two injectors.
