SECU-3 Lite ignition control unit
Has thanked: 970 times
Been thanked: 1628 times
Post 22 Sep 2016, 23:58
Discussing SECU-3 Lite ignition control unit. It is cheap, simple and ignition-only ECU with embedded MAP sensor and coil drivers (BIP373).
SECU-3 Lite units are available for ordering. Only 60$.
We can send SECU-3 Lite to USA, Russia and other countries. To place on order, please write to order@secu-3.org.
http://secu-3.org/blok-mpsz-secu-3-lite/?lang=en
Page with other items available for order http://secu-3.org/order/?lang=en
NOTE that some cheaters try to fabricate SECU-3 units or pass slightly modified versions as own developments thus violating my author rights! Be careful!
Post 19 Oct 2016, 00:08
Re: SECU-3 Lite ignition control unit
This article can be useful http://secu-3.org/secu-3-comparison/?lang=en
Comparison of SECU-3 units
Post 31 Dec 2016, 05:05
Configuring SECU-3 Lite board:
Post 31 Dec 2016, 05:07
Post 12 Feb 2017, 03:11
Bluetooth board for SECU-3 Lite unit with DIY polygon. Some optional components for connecting of a tachometer are also here.
http://secu-3.org/secu-3-lite-bluetooth-module/?lang=en
Post 11 Mar 2017, 16:02
Bare PCB for SECU-3 Lite.
Strecek
Post 04 Dec 2017, 22:27
Hello, I would like to use SECU-3 Lite unit to run Tatra V8 engine with eight pole VR sensor in distributor. (distributor with cancelled centrifugal and pneumatic advance regulator).
Please do you think its possible ? As I tried to check firmware and I found only Hall sensor version of distributor.
I would like to use dwell control as well.
Thank you
Strecek
Post 05 Dec 2017, 00:04
Strecek wrote:Hello, I would like to use SECU-3 Lite unit to run Tatra V8 engine with eight pole VR sensor in distributor. (distributor with cancelled centrifugal and pneumatic advance regulator).
Thank you
Strecek
Yes, it possible. You should connect your VR sensor to CKPSx inputs and use firmware for Hall (and use high voltage distributor). Also, you may need to solder 100k instead of default 470k (resistor R32). It may be necessary if your sensor is too sensitive.
tmarkala
Your CAR: Nissan HP10 Primera
Post 08 Dec 2017, 02:33
Hello!
I'm looking to convert Nissan SR20DE engine to carburetors.
Do you have any experience with Nissan CAS optical sensor which is located in distributor?
Could SECU-3 use its position signal?
Various trigger wheels can be used. For example:
https://www.diyautotune.com/product/50- ... or-ka24de/
Thanks
Tomislav
Post 08 Dec 2017, 15:02
It doesn't matter which type of sensor used - VR, Hall, Optical. The configuration of trigger wheel is important. Trigger wheel shown on the picture has 2 sequences of 12-1 teeth and 1 gap for determination of 1-st cylinder for full sequential operation (2 sensors).
SECU-3 firmware should work with mentioned trigger wheel, but note that SECU-3 Lite has only 2 ignition outputs and you can't use full sequential ignition on 4-cylinder engine. You can either use SECU-3 Lite in semi-sequential mode or switch to use SECU-3T if you want full sequential. For semi-sequential operation one sensor is enough (reading of 12-1 sequences).
2 x 12-1 plus gap for full sequential operation.
Return to Hardware
