Pre-release software updates (for testing)
Has thanked: 878 times
Been thanked: 1487 times
Post 09 Jun 2017, 20:39
I will post in this topic pre-release software binaries for testing (recommended only for experienced users).
Post 09 Jun 2017, 20:41
Re: Pre-release software updates (for testing)
Software with full CDI support (spark on rising edge).
Secu-3 Manager
Firmware files
Post 10 Jun 2017, 10:06
New updates:
SECU-3 Manager
Firmware
- better support of synchronization from a hall sensor (accuracy of ignition timing);
- limits (min, max) for IAC position were added. Applicable only in closed loop control mode.
Post 05 Jul 2017, 00:09
First software test release for SECU-3i published today http://secu-3.org/04-07-2017-first-test ... i/?lang=en
SECU-3 Manager download/file.php?id=4822
SECU-3 Firmware download/file.php?id=4821
Post 18 Aug 2017, 02:55
New updates:
SECU-3 Manager
Firmware
Added support of the full sequential injection!
Post 26 Sep 2017, 23:24
New firmware and SECU-3 Manager for testing. More information in Russian.
Download links:
SECU-3 Firmware
SECU-3 Manager
Post 02 Jan 2018, 17:18
New test release available! What is new: Alpha-N, gas injection, barometric correction etc.
SECU-3 Firmware
SECU-3 Manager
Post 10 Jan 2018, 14:11
New test release. What is new relatively to previous publication:
  • Air density correction map added! (additional to embedded correction)
  • I rewrote Alpha-N(TPS) and mixed (MAP+TPS) modes
  • Improved MAT/CLT correction
  • Other minor fixes and of course, new bugs too :D
SECU-3 Firmware
SECU-3 Manager
Post 16 Jan 2018, 13:47
New test release. New features:
  • Separate look up table was added for correction of cranking ignition timing vs coolant temperature
  • Check box for selecting between absolute pressure or differential pressure (gas pressure - MAP). Mentioned check box selects which pressure should be used by horizontal axis in the PW correction vs gas pressure.
  • Added ability to edit TPS threshold for activation of flood clear mode.
  • Two new parameters were added to the Temperature tab. These are: minimum RPM for turning on of air conditioner (clutch control) and timer for cooling fan.
  • Some minor bugs were fixed.
SECU-3 Firmware
SECU-3 Manager
Post 02 Feb 2018, 21:45
Return to Software relaeses and PC software
